Initial impressions on new Turbo S
- Thread starter grover
mnk303
ORIGINAL: tscaptain
Oh yes!ORIGINAL: rholyoake
Have you noticed any problem with condensation on inside of rear light clusters?
http://www.porscheclubgbforum.com/tm.asp?m=529193&mpage=1&key=condensationò¦
http://www.porscheclubgbforum.com/tm.asp?m=542650&mpage=1&key=condensationò„¥·
Just got off the phone to local OPC a known issue and its they say because the lamp units now use LED's and they run cold where before the units had bulbs that ran hot and they dried out the units, they said they had tried replacing the units, "no good", there has been no cure by Porsche and TBH its nothing to worry about, I said actually he is right, even my A6 has the problem, my 430 had water in the front head lights and I was told it has to be there for more than 6 hours before Ferrari would consider a change of units, well so far I have not see the issue in the front light unit. Makes sense though.
rholyoake
rholyoake
rholyoake
marlin
ORIGINAL: rholyoake
Have you noticed any problem with condensation on inside of rear light clusters? Couldn't find much on the forum using the search, but few issues when you Google it. Maybe its just been the cold weather recently. For a month old car bit concerned, will mention to OPC when I'm seeing them Friday.
Oh they all do that Sir
ORIGINAL: lowndes
In my view the only thing they have got wrong is the centre locks as standard. I very nearly specced the standard turbo wheels as NCO but regret I didn't have the courage of my convictions at the time. Wrong decision and not easy to rectify and on a road car centre locks are a classic example of style taking precedence over function. Rant over!
Agree with that. The centre lock wheels are a hassle - from cleaning them where there's a gutter behind the spokes which collects the dirt, then on to removing them, where Porsche supply the tool to remove the wheel nut but not a means to turn it, and then the missing tools for removing the centre cap without damage and turning the centre lock to re-engage it. Mine have also picked up a couple of stone chips which I must touch in to prevent corrosion.
ORIGINAL: Hendrik
Is it possible to order the Turbo S without centre lock? It seems that this is a feature nobody really appreciates.
I think the Spyder 'centre lock' wheels are gorgeous - lightweight, motorsport design, reasonable protection from kerbing, stay pretty clean with ceramics, not too difficult to clean (apart from channel behind spokes). What's not to like [
rholyoake
ORIGINAL: mnk303
Let us all know if the change of lights cures the issue please, my POC said they were happy to but it has not made any difference on the 3 they have done so far.
Quick report that it's been a month nearly since Tonbridge OPC changed both rear light clusters due to condensation and absolutely no sign of it returning even after plenty of wet driving conditions and washing.
