ORIGINAL: AndrewS
ORIGINAL: 944Turbo
How much time and money have you spent on your car to get the 340bhp that you have? Equate your labour to £41.95/hr + VAT to make a fair comparison.
That 340 BHP was with a MAJOR boost leak through the ISV, note my graph is way rich as the MAF was measuring air coming in that was then escaping, it is also at lowly! 18psi, my current chips maf will allow more.
The actual performance parts on my car now run to approx. £2,000 off the top of my head, say £2,500 in case i forgot something.
Addmitedly I have used various development options, but to recreate it that is roughly what I would spend and once I have a bit more time will be returning to the dyno and hope to exceed 350 at 18 psi at 21psi I would expect around 370bhp, dont know what my compression is like but the car has done over 180,000 hard miles well the 90k I ave done in it have been fairly hard.
I have an IC and hard pipes to install as well, if I had met Simon sooner probably would be running a more efficient turbo increasing the area under my graph and getting higher numbers at the top.
Davids car I also modded, though Jon M had some input - thanks [
] , It has a standard exhaust, AFM and turbo and made around 370 ftlbs and 320BHP at iirc17.5 PSI, mods amounted to under a £1000.
Labour excluded but I could probably recreate Davids car in around 16 hours working to the high standards I employ at work in the aviation field, at slightly more than £41 per hour
I am an amateur and have found a package that works in my spare time. If I had more time I believe I could do much better.
I dont know what Rick has spent - its up to him and he enjoys the development side, I do know that running at 21PSI he has a lot of monitoring going on to ensure the engine stays in one piece, EGT's, AFR's boost, knock, etc. (sometimes with back up systems).
Not sure how much Paul has spent but he should achieve similar figures with the ability for much higher and has a better and stronger than new engine - he has had t wait a bit longer though [
Tony
