I believe the standard 951 intake manifold to be a very good design given the space limitations of the engine bay. Certainly it posesses reasonably long inlet tracts as required to make good midrange torque. WUF has a modified version of the 951 intake manifold. The modifications are internal to promote better flow and external to fit an air temp sensor for the engine management - something the standard 951 / DME setup is in serious neglect of. The throttle body is also matched and the butterfly modified.
I have to say that the torque curve of MarkK's car bears out my thoughts about the LR intake manifold - the runners are too short and consequently move the power and more importantly torque curve too far to the right (higher rev range). I'm sure that this is OK for an outright race spec engine running consistently in the 5500 - 7500 rev range and relying on high RPM power (and probably with a suitable shorter diff ratio to match).
However, I question its suitability for a road car, partly because a lot of work would be needed to get the engine to rev that high (as Andrew says above, solid lifters would help here) and partly that the 951 engine can otherwise be made to produce good torque, which is wasted by the LR manifold design.
With LR products, not all that glitters is gold ... ask me how I know and have the graphs to confirm it.
During the early summer I assembled a number of parts for a proposed new air intake system (pre-turbo) that will address some issues with WUF's current intake setup that I'm not entirely happy with. I'll be doing a before / after mockup and test at Allan's (Weltmeister) when I get time next year to prove my theory right or wrong before I go to full fabrication. In essence the modification is about increasing torque by changing the way that air enters the turbocharger, and reducing heat soak. I'll publish on this on my website when I've carried out the necessary tests.
Since April (?) I haven't made any mechanical changes except the new mapped boost control system that I fitted subsequent to the last dyno session at Allan's. I have, however, covered around 6,000 trouble free miles, some of it at full chat around Scotland among other places and tours. Only oil changes and one inspection of the plugs has shown that I'm happy with the ignition setup. Oh, and a new set of 245 front tyres. The cars is still on the standard cylinder head and cam (as it has been all year).
I can get well over 400 miles on a tank of Tesco 99 when trying, or about 340-360 in normal use including 85-90 motorway cruising mixed with horrendous London traffic. The car pulls cleanly from 28mph in 5th gear and a lot of the very low rpm mapping was done on the M1 in the 40 mph section!
I strongly believe that a proper engine management system and thorough mapping to be essential to getting proper drivability and shaping an engine's characteristics to get the best of the mechanical mods. The two parts have to work in harmony to create the synergy that separates a good driving experience from a great one. Even slight mechanical changes need to be accounted for to get them to work for you.
Over the winter I hope to get to rebuild the bottom end that now has over 130,000 miles and is suffering a lot of blow-by. Capacity will remain at 2.5 Litres. At the same time the big valve head and a revised cam should make a re-appearance. The original reason the BV head was removed was that I wasn't happy with the compression ratio. I had lowered this in anticipation of running a higher level of boost, but after a lot of road miles changed my opinion based on the altered engine's characteristics.
I now believe that rather than sacrificing CR to the alter of boost, I want to go the other way and use the benefit of the development work I've done with the engine management and ignition setup to allow an increased boost headroom to work with the original or maybe even slightly higher CR.
I've managed to reduce EGT by a significant margin so far and hope the the BV head with suitably modified chambering in conjunction with the special B10 sparkplugs will allow me to reduce EGT even further, allowing a higher level of boost before the onset of det. The aim of this is to produce a broad torque curve for even better drivability and economy and extended power band at the top end. Quite a holy grail I know, but I do like a challenge. There's just something about a GT spec car ...
I'm also considering mapping for 95 octane to get around some of the problems we've experienced in trying to get decent petrol in a number of places including Scotland and Isle of Wight. The advanced J&S knock control system copes admirably with low grade petrol and both retards ignition correctly and displays whats happening, but I think that I 'll develop a 95 map all the same. I've still got to setup the launch control and full throttle gearchange capabilities that I've already designed in to the system.
WUF also has (LR) vernier cam timing so there will be some work with cam profile and lift and then adjustment on the car to fine tune.
All of this work is bespoke. The intake, head and cam design will be to my specification in conjunction with CTM, who will also get to do all the machining on the bottom end etc. The ignition system is entirely bespoke (and has now to a large extent also been tested in another 951 as well).The mappable boost control system is developed in conjunction with Random EMS - the official WOLF-3D distributors in Seattle.
To get a good rounded package by merely purchasing a selection of off the shelf items is at best a gamble. If you add an air filter (+8%), chip (+25%), Exhaust (+15%), would you honestly expect to get a 38% increase in power ? If your answer to that is yes, then your optimism knows no bounds.
Baby WUF (944S) has an ESS rear exhaust system, Blitz chip and cone air filter. Standard rating of the engine is 192 BHP. At Allan's it currently produces 173 BHP with the mods listed. Yes, that's 192-173 = 19BHP nett LOSS! This is almost certainly due to valve guide wear (it has new ignition system, bits of wiring loom, knock sensors etc to try to locate the problem).
If you're going to modify your car, you need a baseline figure to work to from an accurate dyno to make sure the engine's healthy first. Compare two examples. Back to baby WUF. Cost of exhaust £299, chip £50, intake £25. Additional insurance premium for 3 modifications £150. Additional cost for year say £525 for a nett 19 BHP power loss (this excludes the additional petrol costs from an under-performing engine). Alternative - repair fundemental problem and probably be back to around 190 BHP. Next year spend the money and probably see the right side of 200 BHP.
The cycle of change, test, change, test etc. is the only way I've ever found of getting a full picture and reaching your goals (which will always move!). I've seen some really silly little tricks make a big improvement, and big shiny expensive things produce a nett loss.
In short, get a baseline engine health check - dyno output, 4-way gas analysis, compression (or preferrably a leak down test) and see if your engine is healthy to begin with. If not, spend the money on getting it fixed.
If it's healthy and you want more power, you have a baseling figure to work from. Fit (or have fitted) your modifications, the go back to the SAME dyno.
If you happen to go to Allan's (WRC at Silverstone) you can also compare like for like with other cars / modifications as extensively published on my website.
Either you'll get the improvement that's claimed, or you get your money back and try alternatives.
What does it cost ? Probably £40-60 for the base run (cheaper if you're trade) and you can probably do a deal with the dyno operator in that you get a cheaper price when you bring the car back for an 'after' run), then the same again after the modifications. If you're going for a mid range power hike, then the costs involved are small compared with your outlay for parts / fitting etc. This is the same for both Turbo and normally aspirated cars. Make sure the fuelling is safe.
My advice above applies to ANY make of car and ANY tuner / vendor / part supplier. Either you want to KNOW what's really working, or why not just save your money on the car and spend it down the pub largering a power output of your own choosing (or buy an M316i, get it slammed and fit neons - I know a venue with an inexhaustable supply). This is just sound practice and also the process that would normally be used to develop products / packages as part of bringing them to market.
Sorry for the long post. What was I thinking of! [
