Hi Rob
You really need to check coolant levels when cold, so once day before you drive - otherwise all sorts of erratic readings. I always check for leaks on the floor; oil, coolant and brake fluids after reversing from garage. As mentioned misfires could be coil packs - the variocam sensors can affect idle, but not sure if this would be evident in driving when opened up (in theory possible if not advancing cam, guess it depends on what position they fail). Northway should be able to run diagnostics and let you know.
Otherwise, these cars are fabulous! We need some photos.
