Neil Haughey
I don't want to confuse everyone but a flat i.e. square torque curve will give a linearly increasing power output. To get a flat power output you need a big torque hit low down that gradualy tapers off at higher rpm. This is because power is nothing more then torque multiplied by the rate at which that torque is applied i.e. the rpms of the engine. Its easier to understand if engine parameters where quoted using proper physics units like Newton metres and kilo watts.ORIGINAL: DivineE
I don't mean to offend but I think your missing the idea behind the phrase. Your argument is actually in line with the theory of creating a larger area under the curve.
What they mean is you cant just look at the peak bhp figures and think a car will be fast, actual speed comes from having a larger square area under your torque curve. i.e. power through the rev range not just one peak at the end.
Regards,
Ben
This is also why so much nonsense is often spread around about how wonderful diesel engines are, completely fortgeting that 400 lb/ft at 2000 rpm is in many ways only 1/2 as impressive as 400 lb/ft at 4000 rpm, especially when one considers that a diesel application will have gearing designed to work at the low rpm ranges of diesel engines i.e. the torque multiplication factor generated by the gearbox is totally different so the real torque at the wheels is completely different.
