My project for the coming months:
For some time I have been thinking about methods/ways of keeping the motor warm over winter.
After starting a discussion on Pelican; it would seem there are a couple of different heaters already available in the states.
So, I hear you say why?
Go to the following links and read on;
http://www.skylineaero.com/Engine%20preheater.htm
http://www.reiffpreheat.com/tbo.htm
The main benifits to summarise are;[
Moisture will be reduced inside crankcase.
Oil will last longer.
Motor will achieve operating temp sooner.
Bearings, rings, etc, will last longer.
Less fatigue on crankcase, cylinders; from constant expansion/contraction due to normal use.
If the heating pad (or magnetic heater) can be obtained complete with built-in thermostat, and runs on 240 ac power, then all one would need to do is wire-up a plug. This could be to one side in the engine compartment. At the end of play, each day, park the 911 in it's shed, plug the ready power lead in and close the shed. [
Reading the above links, and the thread on Pelican:
http://forums.pelicanparts.com/showthread.php?s=&postid=1028713
It sounds fairly plausible?
Any one any ideas?
Peter
Any one any ideas?
Peter
