plhorner
Moderator
I personally think it would have to be a custom made tank with an internal heater and flying lead for power connection. If you accept that you'll never achieve full running temperature by pre-heating methods (unless you use a 240V system - wet cars and electricity.... not for me!) you could opt for a 12v system and go for 50 / 60 degree C oil temp (or may be slightly higher - I'd need to look further at trace heaters). This would go a long way towards a rapid warm up of the engine on start-up.
The problem I see with an externally mounted system is like you say, stone damage etc. This would then need to be removable, who wants to grovle around under the car before work ?!!! If its just a case of disconnecting a flying lead from an internal system, I reckon we have something.
Sorry, I couldn't read the attachemnts from Peregrine - computer gremlins again!
Regards,
Regards,
