sawood12
ORIGINAL: DivineE
I've only been in one KW v3 equipped car on a track and that may/may not have been set up properly at the time but I thought the KW's still felt way too soft for track use. Perhaps the perfect option for a fast road car but not really in the track day bracket.
On the other side I've heard people say the Gaz shocks are great for track work but not so great on the road. Perhaps as with everything it's horses for courses.
What are the spring rates of KWv3's vs Gaz off the shelf kits? I'd be surprised if they are softer. Don't mix up stiffness with compliance. They are two different things. KWv3's were built for the track so are plenty hard enough - the valving was designed to ride the kerbs and rumble strips better than conventional singe-rate shockers whilst running stiff spring rates - it just so happens that they are very good at riding our pot-hole ridden roads too.
KW also do the clubsport kit in the v3's if you do want stiffer springs and you can also spec stiffer springs still as a custom spec as someone on this forum has done.
My 944 rode better than any modern hot hatch i've ever driven - the body roll, dive and squat was much better controlled, it didn't lurch around, and didn't crash over every pothole and blemish on the road. The communication to the driver was much better - I swear you could almost feel the texture of the road surface through your bottom with the KW which is something i've not felt on any other car - Boxters, 996's, M3's and most hot hatches. It really brought the feel of the car into the 21st century. I'd thoroughly recommend KW if you can make your budget stretch - don't bankrupt yourself for it or sacrifice the family holiday for it, but if you can stretch the little extra over Gaz (which isn't that much less) then it will be worth it.
Not sure why KW wouldn't suit series 1 cars or 924's? There is no witchcraft going on with the KW's - they are still conventional spring and fluid damper technology just like any kit out there so no reason why they wont work with any car, they just have a clever valving system that varies the damping rate - as sort of passive active suspension.
