Greenslade
Well, today I took my car to my local OPC. for them to investigate the latest leak. As I posted previously, if this is this is a IMS leak it will be the fourth in under three years and the third in fifteen months. If it proves to be an IMS leak, what are my options? Just changing the seals and replacing bolts does not seem to solving the problem. It seems to me from other posts on this issue that there are other possible causation factors i.e. poor lubrication, shaft deflection, bearing wear that are more relevant which could be causing the seal to leak. Any advice on how I should deal with this should the OPC come back with a recommendation just to change the seal...from my conversations with the OPC anything they do is being 'managed@ by Porsche GB. To me the best option would be for the IMS bearing and shaft to be replaced, I do have a Porsche warranty until the end of this year. Just how far could I take this.
Roy
Roy
