LED Dash Lights
ORIGINAL: RICH7105
...I'm not confident about taking the binnacle out and sorting it myself...
I really wouldn't be too worried about that part. I am certainly not mechanically minded but managed to fit the flaming eye kit to mine in about an hour or so - unusually for me without any shouting or expletives too. There is nothing too fiddly about it. The problem it seems is finding an adequate solution.
How does a mirror maker apply the coating to the back of a mirror? Could this be done to the light prism it the stuff was available?
I've tried pretty much all of the options mentioned above (apart from the hat!) over the course of three 944s and a few years.
The FlamingEye kit gives the best results, but the Jager Engineering one is a very close second. Resilvering the prisms is a big waste of time, as is dropping in LEDs to the existing bulb sockets.
Where the original bulbs reflect through silvered prisms and then up on to the instruments, both the FlamingEye and Jager kits remove the prisms entirely and shine LEDs directly up on to the lights. They will always be brighter and more effective than the original setup, whatever bulbs you put in there.
I can only assume the original layout was intended to make the illumination more diffuse, and the FlamingEye kit manages to do that just fine anyway. The Jager kit is perhaps a little too direct, giving three distinct beams of light, but in my experience that's a small price to pay for being able to read the instruments very clearly indeed.
Taking the instrument binnacle out and fitting one of these ready made kits is a very simple process. With a bit of experience I've got it down to a twenty minute job, and I am definitely not the mechanical type.
If nothing else, that could help share the (very high) shipping costs from Canada. When I last ordered from them I bought a big pile of other bits and pieces as well to justify the postage to myself. I also got caught out for customs charges upon delivery.
ORIGINAL: poprock
....but the Jager Engineering one is a very close second....
They mention 'maybe some reflection in the windcsreen' on their website - is this noticable or just a**e covering?
It's noticable, but not distracting. Any bright lights are going to be visible in the windscreen due to the angle of the glass. The white LED versions are a little brighter (thus more noticably reflected) than the coloured ones.
Ha! Another chance to post pictures of my LED's [;)]
Strange, but after several years, I wonder if they are as blue as they used to be.
I have just tried to buy one of the blue clock LED,s (how cool would that be) but alas as I I not domiciled in the US of A this didn't seem to work. Granted I could e-mail the vendor but the moment passed.
ORIGINAL: idwoodvale
It's a metallic coating that is applied to the glass which is why it deteriorates over time due to corrosion.
ORIGINAL: sawood12
If it's like a normal mirror, then it's a reaction of silver salts with something else, which deposits out silver onto the prism.
I wonder whether this could be replicated at home. It's not a difficult reaction - no need to heat or anything like that. It may be possible if there were some budding amateur-chemists on the forum to guide the way.
ORIGINAL: zcacogp
The prisms are acrylic, not glass, if that makes any difference. I doubt that they could be cleaned up enough to attempt re-silvering anyway. You should see the state of these things when you remove them. I know some guys looked into having new prisms manufactured a few years back, but the likely cost for a small run was astronomical.
If there is any reasonable saving to be made then I would be up for it. I'm in no desperate rush to do something with mine, but it would be one of those nice to haves. I wonder if the variable resistor still works for the dimming - not that I actually use it, it's on full bright all the time, but would be nice to retain the original feature.
ORIGINAL: RICH7105
I'm definitely up for a group purchase of the Jager Engineering kit if anyone is interested ?
Rich
Same here to be honest, would be nice to have one before the dark nights are upon us again!
ORIGINAL: RICH7105
Mine currently work fine, so to quote a character from Dragons Den, 'Aaaahhhmmmm Ooooot."
ETA: Good idea tho'!
I've emailed Jager and will let you know what they come back with, in particular I noticed that the shipping cost is astronomical so if we got several orders shipped together and then distributed from this side of the pond that could reduce cost considerably....
Dave K.
ORIGINAL: dlknight
Dave K.
Nice one [:D]
