944cabby
Yes, i was thinking the same - are ther any makes that are more prone to snapping than others?ORIGINAL: charles.y
Why don't they make longer life and more robust belts ! []
Charles
Charles
So if 3 years is the approx life of a cam belt being cautious - should all the rollers, balance belt etc be changed at the same interval or would they be changed based on their appearance at the time of cam-belt change?ORIGINAL: pauljmcnulty
Didn't I read somewhere that Ford are going back to using chains?
I would have thought that, on the basis that rubber-on-metal should only cause wear to the rubber, a regularly-changed belt is better than a metal-on-metal chain?
If, as I suspect, we are nearly all doing less than average miles in the cars, then we've got to budget on a belt every three years. At c. £200 for the job as part of a service, that's only about £70 per year. That's not much more than doing the belt every 4 years, I'd rather be safe than sorry.......
Didn't I read somewhere that Ford are going back to using chains?...
The timing belt interval on my Focus is 100k miles
