Life after Cayman - My 2021 Alpine A110 Legende GT.
Brian that’s a great choice for your new sports car! I had a good test drive in one of the early A110’s as I saw it as an alternative before committing to buying a 718 Cayman 2.0. For me it became an obvious choice because I needed the extra storage provided by the Cayman for planned European trips. Otherwise it was a very close call, I personally felt the Alpine’s drivetrain was slightly better than the PDK Cayman and as a road car the handling was excellent, on a par with the Cayman but with a different dynamic feel. In the end I went for the manual option in the Cayman which suits me better than an automatic anyway.
The only negative I felt driving the A110 was a lack of feel through the steering when the steering was just off centre, eg when committing to a fast turn. I have subsequently learned that the suspension alignment from the factory for the early A110s was not ideal, and this issue would be easily remedied using the recommended ’fast road’ settings devised by Life110 https://life110.co.uk/
Jeff,
A very fair review by PH on the 2021 version of the Alpine 110. It really is as good as it says on the tin. Rarity also trumps.
Today I have just returned from a drive to meet Porsche Boxster GTS friends from Aberdeen at Goodbrand and Ross cafe on the A939 Grantown-Tomintoul route at the Lecht ski centre Aberdeenshire. What a road for the A110! Photos will follow in a later post. Watch this space.
Tested Sports mode for the first time. Excellent gear shifting map on auto mode, I'm still running-in remember. I switched to manual mode for the twisty sections and the gear shifts were comparable to my 718 Cayman GTS PDK. The gearing is close ratio and absolutely on the button.
Photos below of my 718 Cayman GTS and A110 Legende GT at the Tomintoul location in 2019.
Brian
This is the Sport mode dash display on the A110.
The two dials at the top display real time torque and bhp figures. A bit of a gimmick, but in character with the car.
Fuel level and coolant temps also shown. The rev counter is a digital representation.
For your interest my average mpg for 400+ miles so far, has been 37.5mpg.
Brian
As previously posted, I enjoyed a fabulous day out meeting Porsche friends Paul and Loraine Barlow with their 981 Boxster GTS at the Goodbrand and Ross cafe by the A939 Lecht - Tomintoul route. It was my first opportunity to test the A110 on one of the finest driver's roads in the UK. With the summer season tourists long gone, the route was traffic free and the weather thankfully glorious.
For the very first time I engaged Sport mode, just to see its effect upon the character of the car. I chose manual shifting first of all, mindful of my self-imposed rev limit while running-in. The Getrag 7-speed DSG gearbox in the A110 has short, close ratios, which are ideally suited to the light mass of the car. The gear changes are lightning quick in manual mode with a satisfying "pop" on upshift engagement. Downshifts have a generous throttle blip action which sounds good with the sports exhaust automatically activated. The A110's 4-inline turbo engine sounds completely different compared to the boxer flat-4 in the 718 Cayman. From inside the cabin the engine sounds more harmonious than the Porsche Flat-4, lacking the off-beat drone of the 718. In Sport auto mode the upshifts on a light throttle are more leisurely and occur sooner. A more aggressive throttle action changes the upshifts to rapid-fire with the "pop" on engagement. Thus far, the Getrag DSG gearbox compares very favourably with the Porsche 718 PDK. The larger gear shift paddles are also superb.
Two things came to light during my trip on the A939. Windscreen reflections from the dash scuttle and carbon instrument binnacle are very obtrusive. It's especially noticeable when heading into the sun. You do get used to it after a while, but it is very disconcerting at first. The reflections are as strong as a head-up display in certain lighting conditions. The dash scuttle below the windscreen glass has a black crackle finish which does not absorb sunlight, it reflects it. The shiny black carbon instrument binnacle also reflects the sunlight onto the windscreen directly in front of the driver. Under certain sunlight occasions I found myself consciously raising my sight line above the reflection on the screen. On the A939 you have to be aware of free roaming sheep on the road, and signs are placed by the roadside warning drivers to take care. It was under these conditions that the screen reflections became especially obtrusive.
The second thing I noticed was the ride quality of the A110 on the bumpy sections of the road. The 2021 Legende GT has stiffer ant-roll bars, springs, and dampers. This gives the car a busy, fidgety, ride compared to the 718 PASM suspension when set on normal. From my experience I would compare the ride quality of this A110 model to be on a par with the 718 Cayman GTS -20mm sports suspension set on Sport mode. It's also firmer than the ride on a Cayman R. When the A110 encounters bumpy sections of road, the whole body deflects in reaction to the bumps. Being a light car this is more pronounced than on the much heavier Cayman. When hustling the A110 along a twisty B road such as the A939, you have to be ready for the body deflections when encountering bumpy corners for example. The feedback from the steering is so good that the driver always feels in control of the car, and any sideways jolts from bumps are easily and intuitively dealt with from the helm.
I'll post a few photos from my day out at the Lecht. My grateful thanks to Paul and Loraine Barlow for their high quality photos, and also their patience with taking the action shots on the road.
Brian
At Goodbrand and Ross cafe on the A939 where a supercar touring group from the midlands of England arrived unexpectedly.
Brian
Ooof! Putting the Alpine and Cayman profile shots next to each other does the French car no favours I'm afraid.
Agreed.
Also, am I sensing a not-entirely-enthusiastic-honeymoon-period from you, Brian? As of right now, both cars in front of you, would you take the A110 or the 718 GTS?
Twinfan said:
Agreed.
David,
That's tough one to answer at this early stage. I've only had the A110 for one week. It is a very different car to the Cayman, all of them in my experience. The closest in character to the A110 is the Cayman R.
When I have the running-in completed, and I can fully test the full performance potential, and also the touring capabilities on my forthcoming trip south, I'll reserve judgement until after then.
So far I would say the A110 in this configuration is a true driver's car, despite the shortcomings already noted. It does not have the refinement of the Porsche Cayman, but provided the roads are reasonably smooth it can match any Cayman I have owned for cross-country pace and enjoyment. Its quirkiness is part of it's charm in my opinion. Also it is a car ideally suited for such roads as shown on the photos from the Lecht day out. I'll see how it copes with the intercity route, motorway and dual carriageway journeys coming up at the end of this month.
Jury is still out on the verdict comparing it to the Caymans I have owned. This review is intended as an honest appraisal of the A110 warts and all.
Brian
The A110 got the attention of the supercar group at the cafe car park.
It sounds to me like it's not tugging at your heart strings like a sports car should. The best cars I've owned I've known from the get-go that they were good 'uns.
Enjoy the ride, as they say...
That's where you are wrong David.
The A110 is a very appealing driver's car in the true sense of the term. Very much so. Especially with the Highland roads network on hand where I live.
As I said, it's early days. The full picture will evolve in the fullness of time. It's good to change brand now and again if only to appraise what you miss.
Brian
Tomorrow I intend to open up the engine cover for the first time. Time for an oil and coolant levels check.
I'll be very interested to see the engine compartment layout and how easy or otherwise it is to access. A You Tube video makes it seem a quite straightforward operation. My verdict will follow with photos.
Brian
Today I accessed the engine compartment of the A110 for the first time. A breeze to do compared to the 718 Cayman I'm pleased to report. The engine cover access and removal operation proved even more straightforward than on the 987 Cayman. This was pleasant surprise.
The engine oil dipstick and oil cap access are on the top of the engine block, as are the twin coolant reservoirs. No oil top-up was required, only a small amount of coolant to top-up the left hand reservoir was all that was needed.
The alloy engine block and Getrag DSG gearbox is mounted transversely, just forward of the rear axle centre line. The installation is neat and tidy with easy access to the air filter air box at the top left side of the engine bay. All pipe work and electrical connections are nicely secured with no signs of chaffing anywhere.
The engine cover itself is secured with quarter turn fasteners and is easy to remove and install single handed. The rear glass window hinges from the top adjacent to the roof, and is propped open with a metal rod which clips into place. The entire oil and coolant check was completed in less than 10 minutes. I'm very relieved that this essential operation is so easy on the A110. I don't know why Porsche made engine bay access so tricky and labour intensive on the 981 and 718 Caymans. The risk of damaging plastic trim pieces and fasteners on the 981 and 718 is a deterrent that many owners may find too hard to bear. Consequently, air filter replacement on these models is often overlooked as a result.
No such difficulties on the A110 thankfully.
A few photos with explanation captions to follow.
Brian
Three plastic wing bolts secure the rear glass screen, and are accessible from the open luggage compartment lid.
