Low Temp Thermostat - Fitting
hi, I fitted a new low temp whaler thermostat that I bought from e-bay for £50 a couple of weeks ago. I fitted it with the car on my grass lawn only having raised the n/s/r wheel on a caravan leveller block. it was a easy fit with the only problem being getting the system re-filled with the same quantity of anti-freeze as I had removed. I eventually left the car overnight after refilling to discover that that the expansion tank was empty in the morning allowing me to re-fill with the balance of anti-freeze. hope this helps. regards ray. ps you will kill the grass if you spill any anti-freeze on it as I found out!!!
