LPG S2
- Thread starter tref
vitesse
ORIGINAL: F1Flyer
Try RS Components? Big range of thermocouples and related kit.
I had a look at RS... hugely expensive for a display, but then I expected that... Then I strated trawling the net, and discovered that it would seem that an awful lot of Digital Multi Meters have an input for a K-type thermocouple, range of -40 to +1000 C.
There appears to be a selection on the Maplin website between £15 and £30. Obviously I'll need a thermocouple or two as well, but any experiences of using a DMM for temperature measurement?
I really just want to take some "before" measurements to make sure "after" isn't significantly higher!
I must also do some more scientific performance measurement with my little G-Tech thing as well.
Regards,
Tref.
sawood12
The only other thing i'd want to understand is that our cars have KLR's that run our cars upto knock in real time. I believe that most other cars - even new cars, don't do this. The knock sensor basically is a vibration detection device that is looking for the tell tale vibration signature of knock in amongst the mish mash of other vibration signatures coming from the valve train and other moving parts of the enigne. My question is - does LPG have the same vibration signature as petrol when it starts knocking? If not then you can risk running the car in the knock condition.
pauljmcnulty
I was under the impression that LPG is not more economical that petrol in terms of MPG, but due to its cost is far cheaper to run.
LPG is slightly worse for mileage, but half the cost, so works out significantly cheaper over high mileage.
As I understand......[&:]
Interesting question - not one that I had considered.
Why would the knock signature on LPG be any different to the knock signature on petrol? They are running at a very similar temperature, in the same engine, running at the same speed. I would have thought that the knock signature would be identical.
I would have thought that the knock signature would be far more dependant on the engine type than on the fuel type.
BUT this is all written from a position of complete ignorance. (Did I tell you that I failed a Mech Eng degree once?)
sawood12
It's a good question - carry on brainstorming! (Are you an engineer? Looking at thinking such as yours, I am realising why I failed!) I simply don't know enough to shed any light on it, but it's a very good question. I guess that the different (higher) octane rating of the LPG over the petrol may change the knock signature - but given that it is a significantly higher octane, it may well be that it simply cannot be made to knock within the ignition timing envelope such as can be set by the S2 ECU.
Not sure about the RR's not having knock sensors. I don't think that they are *that* primative! OK, the early ones may be, but the later ones probably are not, and I think that LPG is a popular conversion for a wide range of them age-wise. .
The next question is whether the knock sensor is wired into the new ECU ... it is wired into the existing one, but is there the facility to wire it into the new one? Is the new one a stand-alone system or a piggy-back on the existing one? Is the new system specific to the 944S2 that Tref has, or a generic one-size-fits-all affair?
Is the Pope Catholic? Will the Olympic stadium be built on-time? Will Brown win the next General Election? Is the Porsche Cayman S better than the Lotus Europa? Is there life on other planets?
I dunno! I'm off to ask my cat. (Dammit, she woke me up at about 2.00am this morning with a dead spider - she owes me some answers!)
P.S. I may or may not have had half-a-bottle of good Argentine red before writing this.
xenon
A friend of mine (auto electrician and former land rover / range rover mechanic) has done a few succesfull conversions, was chatting to him today, he said that valve wise any car that can use unleaded should be fine on LPG, but the key is to run a little richer to keep the temps down. His brothers range rover with a TVR power engine runs gas - a conversion he did - apparently you get no carbon build up within the head at all. He offered his exhaust gas analyser and we may be able to get him interested further, he is mainly into audis but I am trying to convert him
Good luck,
Tony
Jon Mitchell said exactly the same thing about teh lack of carbon... which I reckon has to be good for the oil too... but I am surmising... which may go some-way to explaining 300k miles on the other 944 that has been converted.
Certainly any assistnace and feedback of other experiences are all useful...
As to Knock sensors, where are they? I don't recall ever finding any on the earlier 944s, but then, the engine loom usually stays with the engine when the latter is removed from the car, so it could be that I have never noticed them.
Regards,
Tref.
But then I am looking for all the positives I can get at the moment!
I spoke to the person that had the problem with the tappets today, and it does indeed sound like valve seat regression - that is on a Mitsubishi something or other, but hasn't suffered any more problems since the initial installation two years ago.
sawood12
However part of the point is that I don't believe that the vast majority of modern cars have knock sensors, even to this day. it was the system that alot of German maunufacturers adopted, probaby because of the autobahn where long periods of high speed running can bring on knock. It is certainly the case that the vast majority of aftermarket stand alone EMS and aftermarket ECU chip systems don't have knock protection and rely on good accurate and cautions mapping to avoid knock altogether.
The irony of the much (much) higher octane rating of LPG (I think it's about 106, from memory) is that if you were to build a LPG-only engine, you could put in a massive compression ratio with serious advance, and get a really good slug of power out of it. And good economy as well. On cheap fuel ... yum!
Most people however start with a petrol-designed engine, and produce a hybrid that is more tuned towards petrol than LPG, hence never really realise the full potential of the LPG.
vitesse
ORIGINAL: sawood12
Didn't realise LPG was higher octane than petrol. On the basis our cars are only capable of +/- 6 degrees of advance/retard then I guess you are probably unlikely to get into a knock situation then so maybe it isn't an issue.
I thought that all cars running electronic fuel & ignition mapping were fitted with knock sensors to enable optimisation of ignition advance with fuel enrichment for performance & emission control.Both my Honda V6 engined Rovers and 4 cylinder Turbo Vitesse Rover had them;the engine control diagrams showed them.That was over 10 yrs ago.
That's my understanding as well. It means that the ignition advance can be aggressive as possible, given the other variables (temperature, fuel quality, ambient pressure, RH etc etc etc). It is one of the feedback sensors into the ECU of a lot of modern cars, I think ... and allows the ignition advance software to work pretty much asORIGINAL: VITESSE
10 Advance ignition as far as possible.
20 If it pinks, back off the ignition until it stops pinking.
30 Goto 10.
(But I could be wrong!)
sawood12
Read a pretty snazzy article on the next generation of engines that are being developed and should be hitting the streets in about 5 to 10 yrs time. They are Diesel/petrol engine hybrids that offer the advantages of both systems. They basically have variable compression ratio either controlled by eccentric big end bearings on the crank (the mercedes route), or by trapping some of the exhaust gas in the cylinder to increase compression (the GM route or shortcut). They use petrol, so none of that horrible Diesel stuff, and operate as a diesel engine at partial throttle conditions and when you are pressing on and at WOT switch over to spark ignition cycle. The really tricky bit that is real crux of the reasearch and development is how to control the enigne when it is in transition between the two cycles. They reckon you'll get better than diesel economy with all the benefits of the better perfomance of a petrol engine. Sounds pretty good and best of all it spells the end of that horrible, smelly, filthy diesel stuff.
