Hi guys,
The RS with the LSD I understand should not have the brakes tested on the equipment that rotates the wheels individually. However, if the gear is in neutral presumably the LSD is not "engaged" (correct term?) so would it be OK? Otherwise it will have to be done by another method - can't remember what it was called. I'd be interested in your thoughts.
Harry
Harry
