mr brightside
I'm not sure what the abbreviations you're using are.
AFM- air flow meter?
AFR- air flow rate?
Does this mean you are designing a system to measure volumetric flow rate rather than mass flow? If so are you having to find a way of compensating for altitude and temperature? It all sounds very exciting to me, you must be good with electronics!
AFR- air flow rate?
