Thank you for your replies. I was aware of the Vitesse and Scivision products, but for me, they're both far too expensive, for the gains that they are able to offer. The car is an 8v Lux, currently running Bosch ML1.2. I was hoping for a cheap and simple MAF upgrade that could be sourced cheaply from another vehicle and adapted to work with a later ML3.1 ECU.
The more I look the more certain I am that a MegaSquirt system is the answer. Id considered the Vitesse products recently and youre looking at £1,100 (and that's just for the MAF and a piggy back ECU) excluding delivery, duty and VAT and even then you're not getting nearly as much in terms of features or (ECU) performance as MegaSquirt offers.
As I mentioned in my second post, virtually identical ECUs were used in same-period BMWs (as well as AUDIs and Volvos), so I was hopeful that there'd be a number of older BMWs that were now running a MegaSquirt ECU. It seems that all you need to add a MS system to an early ML installation, is an air temperature sensor and a new throttle position sensor. A number of sites suggested cannibalising the existing ECU for the plug, but a better solution appeared to be building the MS into the original ML ECU chassis. There's plenty of room inside to wire the connector and it'll be easier to mount and far more durable, so that would be ideal. After a little more digging I found a British firm who offer a MS already built into a Motronic control unit for £400. If youre happy to assemble your own kit then you could be ready to go for just over £100 plus the required sensors, which will cost very little from a dismantler. With a pin-out diagram and a Dremel it can be mounted in an old OEM chassis in next to no time.....
