PSH
Hi Guys
A plea for info from any 951owners who may be currently working under their car. A while ago I mentioned that I was thinking on relocating my air filter's position to somewhere more accessible and with more room for a larger filter as the one that I have currently is too small. The place that I would like to fit it is behind the central lower intake under the number plate. I want to fit as large a filter possible behind the intake, it will most probably be a cone style filter which should give me the maximum intake area for this position. Now I can't get my own car on the ramps as my son is flat out with work so don't have the use of his garage to allow me to take proper measurements of this area which I suspect is pretty large so I thought why not ask if any of you guys might be currently working underneath your own 951's and if so could you measure what area there is to play with. The largest K&N cone that I've seen is 8" at it's widest and 6" long so this is the type of area that I need, if I can find a bigger filter I'd probably go with it if there's enough room....the filter will be connected by a metre long length of 3"ID flexible hose which should reach easily enough.
over to you chaps..
Pete
over to you chaps..
Pete
