Measuring boost level?
- Thread starter poprock
sawood12
An MBC doesn't block the pressure signal at all. The wastegate diaphram will be exposed to the full boost pressure which will continue to rise until the preset max boost pressure is achived. After which the output from the MBC will remain at a constant pressure. This setup to me is pointless because it is still the wastegate spring that regulates the boost and not the MBC (assuming you set your MBC to a higher boost pressure than your spring).
When I installed my DPW and set the boost pressure to stock I immediately got 20bhp, so the single port wastegate was costing me at least 20bhp.
