So I've threatened this for a while, but finally booked a test session at Mallory Park this am. Track was dry and quiet, typical Mallory mix, a 1950s elite, an A45 (really), a britcar mustang, a couple of G50s Ginettas, and some ex-lemans ferrari (?!). Managed 44 laps of decent time. Comments on the experience.
Its kind of like a big heavy caterham in many ways. Turn-in with a trail braking was OK, but the car clearly understeers, and was shocking at hairpin. But I think we all knew that would be the case.
Car has plenty of power, out of the fast corners, but 2nd gear seemed very low for the hairpin, didnt fancy first though.
The brakes are shot! [
] After the first session the rears were smoking quite a lot. The pedal went long after 20mins (but made H&T easier). And the front have major vibration, I was triggering the ABS (in the dry) quite a lot. Clearly not right. New disks / pads all around required I think. (After Brands?). So I lost confidence in the brakes and had a couple of minor issues at turn in to gerards and missed the hairpin a couple of times.
There were only a couple of times I got scared, once at the devils elbow (think mini bomb hole), turning the car in, it goes light then grips at the front, which rotated the back if I had too much lock on. No huge drama, but I did back off a bit then. Gerards was a good exercise in dialing out understeer, but the car can be adjusted on the throttle quite well (albeit, it was slower). I left lots of room on the exit of gerards where the bump is, for lack of on the limit trust.
Lap times, I got a best of 55.5 but could lap consistently in the 56 / 57s.. Optimal lap (from stringing best sectors together) wsa a 55.1, so kind of OK.
I still ran on the old S02s, and they were pretty horrible but communicative. I didnt bring a pump or tyre pressure gauge so they may be out a bit. So with the brakes sorted and decent rubber, I can imagine, knocking maybe upto 1sec off that. I guess the car is capable of more, but dont think I am yet. I can see there is time to found on the exit of gerards on through devils elbow, but I'm not brave enough yet.
Planning on going to Brands indy if the weather hold next wednesday. But will be cautious as still on grumbly brakes and old tyres.
Overal, the car is a joy to drive, or will be when its setup (geo, brakes, tyres, flat floor) in the interim it is quite entertaining, although it still seems to command a lot of respect. Photos to follow.
