AndrewS
ORIGINAL: 333pg333
For those who run slicks on their cars, Andrew and Paul, I'm interested to know what changes if any you've made to your sump to guard against the significantly higher chance of oil starvation. Also Andrew what suspension do you have in your car and what sort of springrates? From memory Paul I thought you had a stock sump? On one hand I'm delighted that you've not had any issues with your motor, but I'd also talk to Jon to cover off what he might think just as a precaution. If I'm out of line tell me to get back in my box. It's only out of concern of course. Then we get into what oils you use on the track..........perhaps leave that for another thread?
Hi Patrick,
Suspension:
Standard car with 1990 original Boge suspension suspension; later fitted with KW Variant 3. All road settings, but a little more front negative camber. Spring rates are standard.
Sump:
Standard baffled 951 sump. I never had any issues in 3 years of Porsche Cup racing (using very hard springs and ProTrac dampers) and have never had an issue (with oil starvation) in what has now been 11 years of track days.
Oil:
Fully synthetic - either Royal Purple 10W/40 Motorsport or Halfords 5W/50 Trackday oil. Trick is to keep the level just above the max mark on the dipstick.
Tyres:
Originally Pirello P-Zero Porsche Cup slicks and nowadays I use Avon hard compound slicks.
Driver:
Ask those that have witnessed the car or experienced a passenger ride. ;-)
Regards,
Andrew
