Craigybaby
Evening all.
Spent two hours removing sill trims on both sides. Probably about a mugs worth of crud and dirt fell off or I removed with a small wire brush. Apart from some light surface rust I think the center structural parts are OK and the wings are a little crusty with a couple of very small holes so I'm going to see what a body shop makes of them. Is it likely they'll just use a bit of filler?
When my car was resprayed a few years ago and undersealed at the same time it looks like they didn't bother removing the sill trims so they were fairly well glued on with the underseal but now I've taken the trim off the underside is exposed so what would people recommend to treat them with?
Lastly, for people who have had sill work, did you bother putting the trims back on? Im not sure if they're more trouble than they're worth? What purpose do they serve?
Regards craig
Regards craig
