As a consequence of this thread, I had a play with a half-empty can of Dynax over the weekend. I had stripped the door cards off my S2 to fit some new central locking parts (the ones that always fail) and I thought I'd put some more Dynax in to prevent rusting while I was there.
Using the standard aerosol spray cap doesn't appear to produce much flow of product at all; it produced a lot of mist and spray but nothing too substantial. However closer examination showed that the mist was fine droplets of the product, not of the propellant, and it settled in a gentle coating on everything. The difficulty was that the mist was
so fine it blew around and quite a lot of it blew away.
I swapped it for the application lance with the brass nozzle in the end (which I had to clean with compressed air and white spirit as it had blocked from sitting in my workshop for a couple of years!) This produced very different results; a thick coating of product in just about every direction, and the difference was quite noticeable. Pulling the lance along the seam at the bottom of the doors had the stuff flowing everywhere, thickly, and it trickled into all the nooks and crannies (and quite a lot of other places as well, including a solid jet across the carpet in the driver's footwell [
]). On that basis Craig, if you did something similar with the lance in your sills then I'd suggest that you probably got oodles of the stuff exactly where it should be. I can understand the problem with not being able to see it though; it is a mid-brown colour and very hard to see against a dark background until you get used to what you are looking at. It foxed me until I stuck my finger into a puddle of the stuff and realised what I was meant to be looking for.
(An aside, but I can also testify that it is tricky stuff to remove. A good scrub with acetone eventually removed it from the carpet but the splashes on clothing have proved remarkably resistant to the powers of a hot wash with washing powder. That which dribbled down the bodywork eventually succumbed to warm water, a sponge and some Bilt Hamber car wash but it I fear it won't come off the sponge.)
