Dekker
I was told by Chris Franklin at Centre of Gravity that a stock car will not run safely at RS height as the steering links are at the wrong angle ie pointing upwards at the hub end.
This will make steering geometry work against you when the suspension is under further compression thus adding to the pull on the steering causing severe kicks to the steering when going over pot holes and the like as well as much increased tramlining.
Steve has his set at the limit.
It does sound as though your car has had some RS components added, so if they have, RS height would be OK if all of the differences have been added.
It is very wrong to set the ride height by measuring to the wheel arch. It should only be done as per the book to the bolt head on the front lower wishbone and the boss on the rear trailing arm.
There is almost a 5mm difference in wheel arch measurements on my car and no it hasn't been in a shunt, just differences that were normal back in the 90's. I don't know if the robot's that build the new cars have tighter tollerances.
