MOT & LSD
- Thread starter John Sims
ORIGINAL: Diver944
.......so thats why Tony can corner faster than me [] [
Oh yes I'm sure that must be the case..............NOT!!! [
My understanding was you shouldn't put LSD's on the brake rollers but my MOT station didn't seem to know if this was the case or not. We did road test the brakes ......I'm still finding particles of the testers bodily fluids on the inside of the windscreen. [
[:'(] That's disgusting!ORIGINAL: John Sims
I assume the rollers apply torque to each wheel individually and separately. Under test the LSD thinks one wheel is spinning (because the wheel has more torque applied to it than the other side and so doesn't stop) and tries to lock up. If it locks up the previously stationary wheel then has to instantly spin the stationary rollers up to the same speed as the torqued roller. [
I don't know this to be the case and would be most grateful if someone could tell me if I am right or wrong.
sawood12
George Elliott
It is irrelevant that what the other wheel on the axle is doing.
In a car with an open diff, it will be doing nothing IF the wheel being tested is on the same side as the Crown-wheel.
If the wheel being tested is NOT on the same side as the Crown-wheel, then both wheels have to be turning - as its (the wheel being tested that is on the opposite side to the Crown-wheel) drive comes thru the diff - via the Crown-wheel).
If the Car has a LSD, then both wheels on the Axle WILL be turning, - but the Brake Tester Unit only looks at them one at a time for its measurements, and what the opposite one is doing - ie: turning or static does not matter.
I know this because I sat in 3 different cars with LSD being tested on an Automated MOT Test.
I know the diffs are working because of the Cars behaviour[
George
964rs
944T
ORIGINAL: George Elliott
.......If the Car has a LSD, then both wheels on the Axle WILL be turning, - but the Brake Tester Unit only looks at them one at a time for its measurements, and what the opposite one is doing - ie: turning or static does not matter.....
It might not matter in so far as the test results are concerned but I don't realy care about the test results. What I want to know is does the test have the potential to damage my drive train? From what I have read above I believe it does.
George Elliott
definitely no damage or potential damage either, nor even any wear - basically the wheels are free to do what they naturally do as influenced by the open diff (no drag side to side) or Ltd Slip (drags side to side).
The torque plots on some of the engines on this forum - now they could damage the diff [8|]
George
sawood12
ORIGINAL: Diver944
I've heard this mentioned before but don't know if it's just hearsay [&:]
Anyway mine has been tested fine on the MOT for the last five years that I've owned the car.
Maybe my LSD is bust (so thats why Tony can corner faster than me [] [
Hilux
the opposite direction for a conventional open diff and the same direction for an LSD. I've not actually made this observation.
I have cos when I buy a car that SAYS it has an LSD I want to know[
If you have an LSD and jack the car up when one wheel is rotated the other will rotate the same way. A non LSD will have the wheels rotate opposite ways.
Or not at all. Spin one wheel and nothing happens to the other. When working, repaired or replaced they make so much difference. I had my stock 40% rebuilt in the interim and even on the crap kumho ecstas that I use on the road, it gripped way better than before. It's a must on any performance car in my opinion and a forgone conclusion if you ever go to the track.ORIGINAL: Hilux
I have cos when I buy a car that SAYS it has an LSD I want to know[]
George Elliott
Agree that LSD should be in all performance cars, once you get to 200bhp with 2 wheel drive , its basically 1 wheel drive without limited slip.
Just admiring the spec of your car, whats the mph / 1000 in top, and the 0 to 100mph time - brisk I imagine[8D]
Oh, - and with a LSD do the wheels turn the opposite direction to us over here compared to Oz[
George
944T
964rs
sawood12
