david2455
Update:
So I took the 987.2 to Richard and he kindly switched on the multifunction, thanks Richard, and it works perfectly. In summary then the retro-fit MFSW on a previously non- multifunction 987.2 only needs (the wheel and) programming and whilst Richard was pretty good with the PIWIS2, it looked a straight forward change! No other modification. Richard could see an airbag fault, which cleared, presumably caused by me changing the wheel without cutting the battery power.
Next I'll have a go with the 981 and see if that can be made to work without further modification (this is a non heated MFSW). However following comments I did get a paddle version form OPC Silverstone (about £650) and I am very impressed, it certainly enhances the interior and makes the manual shift much easier.
