My 944 1uz-fe V8 swap
- Thread starter Eldavo
Diver944
Thanks Paul [ORIGINAL: Woodsport Hi Diver, the 1uz-fe is from the Lexus LS400, 260bhp and 270lbs.ft of torque in the earlier ones (which mine is) ,
nicksonmsport
Diver944
Diver944
George Elliott
George Elliott
Paul, looking at some of your achievements, this 948 will be a good job. I have always fancied the inverse of this, a 928 lightweight, 1200kg with 4 cylinder turbo and 5 speed manual, it would be a very quick car, and handle extremely well. I suppose you could call it a 924??[8|] 924 turbo [i hope the end product shows how good something like this can be.
George Elliott
The sump is made up of two sections, a cast alloy upper pan that bolts to the engine and a lower steel belly that holds the pickup pipe. Sadly going dry sump is not an option because i have nowhere on this engine i can mount the pump without huge modification. It is going to be easier for me to just make a new all in one steel sump that clears everywhere i need it to.Is the sump integral to the engine block structure or just a container? You thought of dry sump, it may help overcome issues, ------ but cause too many others??
