just smile when the Nova/Corsa brigade pass you
Unless they are going the other way, they'll have to ctach me first [
In 3 days I have already noticed it gets more respect than the C4S did.
The manual only talks about "wearing in" of the moving parts and to avoid high engine speeds for for the first 3000 km. The dealer just mentioned to avoid going over 4500 rpm for the first 500 miles.
It does not mention avoiding full power, although I thought it wise to give it a couple of hundred miles first.
I got the driving experience stuff through around the start of July and replied quite promptly. I had wanted to do it in July but couldn't fit a day in, so went for August slot.
After the letters are sent out, the slots get booked quite quickly.
I don't understand why I can choose everything on the car, including whether the sun visors are covered in leather, the colour of the seatbelts and whether there is a light in the footwell, but I can't choose the make of tyres. I'm told it is a factory restriction and the dealership can't influence it, but if you tell them when you spec the car there would be enough notice for the factory - so I don't see the argument. Anyway, I doubt the rears will last too long.
Observations so far:
I've already confirmed what I noticed on the test drive, the clutch is lighter than the C4S with a slightly more agressive bite and the brakes, although the same size, stop more effectively for less pedal pressure. I'm not sure if there is less torque right at the bottom end (e.g. 1100rpm) since when in traffic it seems slightly more awkward to pull away very slowly. Although reversing seems easier than before and less prone to stalling.[&:]
The sports seats hold you better than the comfort jobs and the Bose system has more bass and treble definition than the Porsche sound upgrade system.
There's one spec of dust in the paint on the fuel flap (not enough to worry about given the stone chips the front is going to get).
There is something slightly loose in the cabin at the back, so not squeak and rattle free, but then the C4S wasn't either. If it annoys me too much then I might have to investigate.
The short shift is stiffer, is indeed short, feels much more solid and is great.
