...looks like this at the moment:
Did a trackday at Goodwood 3 weeks ago as practice for the Speed Championship sprint, noticed drops of oil on the ground between runs and oil all over the engine cover. Left the car in the garage overnight, and found a 4" pool of oil under it next day. Turns out it was the through bolt seals leaking, Anyway, took it to GT One, and decided to strip the engine right down. Turns out the bottom end is pretty much fine, just need to polish out a couple of marks on the big end crank surfaces. However, they did find a small crack in one head by the inlet valve guide, so a new/replacement head needed there:
and also one of the bolt holes where the engine mounting yoke is fixed has broken:
Apparently this is the second RS they've seen in the last few weeks with this kind of failure, probably due to the stiffer engine mounts.
Oh well, at least I'll have a fresh engine out of this, though it probably means no more track days this year (2000 mile running in needed).
