Brian_Innes
Cigarette Lighter socket malfunction - mystery solved.
Following up on the comments received from Clive and Cliff regarding my fused central console power socket, I first of all checked the distance of the Nextbase contacts were within tolerance as described in the handbook. Checked ok.
I had already looked inside the cigarette lighter power socket barrel earlier, but decided to have another more careful look. Bingo! Neatly concealed at the bottom of the socket barrel was the spacer ring from the Nextbase power socket. It had become detached when the socket end cap unscrewed itself a couple of weeks ago. I had fished out the bits and pieces from the cigarette socket barrel, but missed the spacer ring which somehow had lodged at the bottom of the barrel.
After some very careful and delicate fishing that would do a brain surgeon proud, I managed to remove the offending spacer ring and reassemble the Nextbase power socket correctly.
Fortunately I had another spare fuse, which when replaced into the appropriate slot in the fuse box, my dash cam was back in action again.
This is yet another example of the benefits of sharing experiences, questions, and possible solutions on this forum. This avoided me the personal humiliation, had I left the fault for the OPC to investigate.
My thanks again to Clive and Cliff.
Brian
Brian
