Got out and about today on the Highland roads that I love. Headed north west on the A9 to Alness, took the A862 Struie short cut to Conon Bridge and Falls of Shin. This location is an ideal picnic spot, and the falls were in good form with the recent heavy rain. Ullapool via the A837 was next. I was keen to get some practice with the Macan on single track roads with passing places. I'm still acquainting myself with where the corner extremities are on the car, and also the footprint of the wheelbase and track.
My default setting is Sport mode on the steering wheel dial. The firmer suspension setting deletes the floaty feeling in Normal mode without being uncomfortably jarring. I also love the direct steering, and the body roll through corners in Sport is very well controlled. I'm enjoying the higher view from the Macan after 12 years of Caymans, an advantage on winding single track roads. The 18-way sports seats are excellent now that I have them adjusted to my liking. They hold you securely in all the right places and help to make you feel part of the car rather than just sitting in it. I have the seats set near their lowest position on the floor, and this combined with the small diameter Alcantara steering wheel suitably adjusted, really gives a very sporting feel to the Macan. More like a sports saloon than an SUV.
This was my first opportunity to test the Power Steering Plus on winding roads at speed on the Macan. My initial impressions following my first drive was that it was more attuned to low speed manoeuvring. I would now say there is also a benefit for the keen driver in a degree of extra weighting at the helm as the cornering speeds increase. The PSP is nowhere as good as on my 718 Cayman GTS, but that is understandable given the heavier body weight and four wheel drive configuration. Of its type, the Macan steers pretty well for a near two tonne car.
Setting the gear stick in Auto, and with Sport mode selected, the Macan makes good progress on undulating, winding roads, with the ECU chosen gears pretty much spot-on. Previously I preferred to use manual gear-shifting, but today I found the auto box made a decent fist of the gear choice for the terrain. On a very smooth, recently resurfaced section of the A835 from Ullapool to Garve, I selected Sports Plus mode on the dial. The suspension thus set at its firmest setting is more akin to a track day mode, and if the gear selector happens to be in auto, Sport Plus will drop down at least two gears with an accompanying snarl from the 2.9 V6. My choice is to select manual gear-shifting prior to selecting Sport Plus on the public road. That way the lower gears don't automatically engage and add unnecessary drama with the sudden change in engine note. I drove for about 5 miles in Sport Plus and shifted the gears manually using the paddles. This configuration dramatically changes the character of the Macan, and I have to say I am tempted to have a few exploratory laps at Knockhill just to see how the Macan behaves at track speeds. However, that is for the future. I have now completed 540 miles and so far the car is doing everything it says on the tin.
A few photos follow from my trip today.
Brian
Brian
