Need advice please on buying good 996
- Thread starter Eastern
The LN solution relies on normal oil pressure to lubricate the ceramic bearings and have read that even this is prone to failure and not a lifetime fix (certainly if oil is degraded or minimum oil levels drop - fairly standard maintenance anyway). There is also another upgrade IMS bearing with a direct oil feed DOF (not clear if this an LN bearing or another type). I not know much about its long-term reliability with this upgrade, but apparently it is lifetime. Would be interested to know if anyone in the UK use this upgrade?
LN parts are about £500 for IMS bearing and removal/fitting kit £150 (excl. labour).
wibbaboo
ORIGINAL: wibble
In the market myself next year for a 996 and have researched many articles on IMS, mostly from US forums and youtube. There is much scare mongering out there, so read between the lines. The LN bearing solution is an 'open' bearing and not sealed 'closed' as the original OEM fitment. With over 190K 996s produced only a small percentage have failures, the original bearing has a lifetime guarantee and is essentially a precision part that is reliable. It's reason for failure is rare and very difficult to predict (hence the IMS guardian system). Inspecting oil filters for metal particles after oil changes could help in diagnosis, but this could be pure luck in catching that moment before failure.
Hi Tony - Apologies for hi-jacking thread - please email me wibbaboo@yahoo.com and I can send through the 996 buying scores spreadsheet - PM's are not getting through to you
Thanks Greg
Ripmax
