Negative lead for jump starting
- Thread starter DavidL
ORIGINAL: Fen
It's in the scuttle in front of the driver with a blue alloy cap on it.
fairly certain its plastic and its only on models with the boot release where the key works a microswitch. earlier ones that have a cable from the key lock dont have it.
Tony
cornishgrose
ORIGINAL: cornishgrose
....If you connect the pack to both terminals you run the risk of battery damage and will accelerate the wear of the battery cells.
Why should this be the case ?
The electrical difference between the negative terminal and the car body is nothing at all except when using the starter motor. The resistance of the lead joining the two up is tiny. So why is one end of it OK and the other not ?
timig
I think I must be blind - i have been out to try and find this front battery terminal and simply cant find it. Dont suppose anyone might have an idiots guide picture to the engine bay and battery terminals do they??
Thanks! Apologies for posting somethign that is probably perfectly obvious!
timig
I agree Scotland is hardly an obvious choice for solar power charging, but with the huge greenhouse like window on the 944, and the occasional sunny day I thought it can't hurt? The car is kept nowhere near a powerpoint so constant trickle charging might require constant removal of the battery.
Bottom line is, it can only help. But whether it will actually charge the battery or just reduce the discharge depends on the alarm, immobiliser etc. If you want to measure the standing current drain, disconnect the battery +ve lead and put an ammeter between the battery +ve terminal and the lead. Allowing for night-time, cloudy days etc, anything less than around 20mA bodes well for your plan. Anything more and you will just be delaying the inevitable.
