New 18" wheels, but which tyres ?
- Thread starter ChrisW
As an aside, I stand corrected, the fronts are 225/40 18's. Thanks [ORIGINAL: frogisland Chris - what size tyre are you thinking of fitting to the wheels? As i recall 235's are too wide for 7.5" fronts (235's are ok on 7.5" 17" wheels). I have 2 set's of 8's and 9's made up from front 996/rear Boxster. I have D01J's on one set and DZ02's on the other, 235/40/18 front 265/35/18 rear - the rear tyres also are better suited to 10", but the 9" suit my 968 better. JP
964rsdatabase
jason
He's spot on.....cups, then speedlinesORIGINAL: sapex666 Personally, i prefer the 17s. I love the combination of Maritime and black (but i would, wouldn't i). I think apart from the original Cups, the only wheels that look good on 964s are Speedlines (preferably gold ones).
964rsdatabase
SimonExtreme
I have looked into this a little. From what I can make out, the switch to 18's was due to the availablity of suitable slick control tyres for the series. In a single car race class, it doesn't actually matter whether they ue 17's or 18's and the deciding factor was tyere availability. It has been sugested that the improved times were due to the tyres/compound rather than the change in wheel size. Looking at the benefit of 18's, the story is actually a bit mixed. The biggest benefit is that the tyre wall is smaller and therefore you get a stiffer tyre. This is not always beneficial, so matching wall stiffness to car is really important. I terms of weight, you need to look beyond just the unsprung weight. While unsprung weight is important (1 kg saved here is said to be equal to 10kgs of sprung weight), for the same weight the 18's usually have a greater moment of inertia, which effects braking and, to a much smaller extent, acceleration. However, all that being said, our cars aren't being developed so as to find the last 0.5% in performance so I think that there is little to be gained by going for 18's, other than personal preference wrt looks, or, maybe, if the tyres you want are easier to find/cheaper/ only available for 18's. There are also varous stories about 18's causing extra strain on the suspension that I have never got to the bottom of. Some say it only applies to race cars and is due to the use of slicks, others say that even with road tyres, 18's add significantly to suspension wear. I hope that is all as clear as mud!![ORIGINAL: MelvThree seconds at the Wiessach test track on a 964 Cup Car running slix, actually..[8|]ORIGINAL: ChrisW --- I recall 2 seconds but without knowing the track this is meaningless.
SimonExtreme
964rsdatabase
