New 944 owner. A little help, if you please!?
- Thread starter arumdevil
1 screw is bad - unfiltered air will get in around the filter and it doesnt take much dirt to kill a turbo at high speed.
Occasionally the bolts that hold the AFM to that filter box work loose this may be due to flexing of the filter box (with missing screws) they go into the turbo and kill it.
I had the pipe that comes off the turbo split I didn't realise immediately what had happened - couldnt see the split just the low boost - increased the boost to compensate ( I have an electronic boost controller) the air filter actually got sucked down across the air filter box outlet - that was with one missing screw.
Tony
Diver944
ORIGINAL: 944Turbo
This very problem killed my engine and cost me thousands of pounds (it was worth it tho [
A complete new airbox, with snorkel and filter costs £170 from Exeter OPC
Your boost level is healthy, though a tiny bit high for a standard 86 car, should be a max of 0.8bar IIRC. As long as you are not running lean, the car will be fine at that boost level
The belts are definately due asap if they are older than 3 years
The 'wobbly switch' is like that on most cars and can still work fine, I think your lack of 30 second run on could be the relay. Where in the country are you as you may be able to try someones who lives local before swapping parts willy nilly
peanut
The issue with your central locking. Do you mean when you operate it from outside the car / with a remote keyfob? these are linked to your aftermarket alarm system cos as far as I know they were never an option. You could try something obvious like changing the min 12v battery inside the fob . Or just check and clean the battery contacts. Your fob transmitter may be acting up.
arumdevil
ORIGINAL: Diver944
Totnes, in Devon...
arumdevil
ORIGINAL: peanut
welcome Arum.......... nice motor
thanks Peanut... The key fob is doing it's job, as it works for the passenger's door, just not the driver's. I can hear the motor working, it just doesn't push the lock so I suspect it's the plastic bar as Diver944 suggests.
arumdevil
thanks for that one. just got to get the rest sorted now...
