kcbart
Hi Will
Regarding the seat control, the most likely cause of this is that one of the ball bearings inside the switch has come adrift. Take the main switch cover off and you can carefully pry the switch apart, but be careful as there are small springs, smaller ball bearings and a short metal rod which can all easily be lost as it comes apart. Might be a good idea to place a plastic bag over it to catch anything. Probably worth cleaning the contacts while they are accessible. Getting it all back together with the seats in place can be tricky as the ball bearings need to be held in a horizontal position as you push the parts back together - some people have glued the ball bearings onto the springs or used grease, I replaced mine with map pins with the pin cut down to about a centimeter and a bit of blue tack in the spring to hold it.
To temporarily get the seat into the desired position you can always swap the wires to the motor to reverse direction.
