They look like 997 turbo wheels and brakes
New 996 Owner
- Thread starter beershark
Hi Mike,
I'm also new to the club and fairly new to 996 ownership. I too live nearby on Tolpits lane. It would be good to catch up and I'm quite keen on fixing/repairing the car so let me know if you need any help or a workshop etc. I was thinking about heading to the R21 Chiltern club night on Tuesday if you're keen too?
Guy
Guy
Very nice Mike. They look like 997 Sport Design wheels. They suit the car, but are they 19".
Nice shiny exhaust tips, by the way!
Mikez911
Richard,
yes they are 19" wheels, 265 x 35 on rear and 235 x 35 on front. I am very pleased with the car but I have a couple of niggles.
1. It wont always start in Park, but starts in Neutral always, and when put in reverse an error message on the dash comes up "gear selector not engaged", so I presume there is a sensor/switch for the transmission lever.
2. The PCM unit radio and clock will not retain station presets or time when I set them.
Any help would appreciated
Mike
Mike
It sounds like the Multifunction switch, which on a 2003 996 is on the bottom of the selector lever. The switch unit is available as a separate part, and they are about £190. To change it, you have to remove the centre console and lever assembly. There is also a possibility that the selector cable is sticky, or some debris is restricting it, and not allowing the lever to reach to P position fully, so that might be worth investigating first.
As for the PCM, it takes its time signal from the GPS satellites. It will override any manual setting when you switch it on. Is it reading satellites OK. I can't remember which screen it is on, but on one screen it shows the number of satellites being received. It needs to be seeing 4 satellites to get a position, and hence a local time. That doesn't explain the presets though. Maybe a diagnostic check with a Porsche tester might show whats up.
Aren't we all have the date/time issue and no actual reliable fix/solution found yet that anyone has found? Apologies if this is different
https://www.porscheclubgb.com/forum/tm.aspx?m=1039536
