wolfie308 said:
Looks easy enough in the video doesn't it?.....but I can assure you it isn't. How do I know?......I've been making many different car lenses in clear, red, amber and smoke on an almost daily basis since 2005[
I use a completely different method/material for the moulds, but cast in a similar polyurethane resin. To start, you will need a vacuum chamber to degas the resin. Mine is big enough to take a bucket as I degas the silicone to ensure no bubbles against the surface of the cast lens. To ensure an excellent result, it would be imperative to use new lenses IMO as any road rash on used parts would be replicated and worsen on successive casts.
I don't have a unit to hand to check......how is the glass bonded to the backing case? Have they used a heat softening mastic which would allow the two parts to be separated by oven heating? If someone has a damaged unit and could try it, I'd be interested how heavy the actual glass is to calculate the cost of the resin per lens. The resin is much dearer than you'd think....the stuff I use has just gone up dramatically to about £60/kg, but is the market leading product and best in my experience.
First-hand experience! Fantastic - thanks for posting Richard. [
I've never done this sort of thing but have watched the videos and it's something I'd like to try, but (as you said) the kit is extensive and it would be quite expensive to buy all of it just to play around. A vacuum chamber is the obvious biggie but I wonder if you could make it work by putting a sheet of perspex across the top of the bucket and attaching the vacuum hose to the middle of the sheet? (What sort of vacuum do you need to pull to get the bubbles out?)
I take your point about needing to use new (and perfect) lenses but could you put tape over the front of the lenses before using them to make the mould? That would give you a smooth front. Or use some wax to fill any minor imperfections?
The glass isn't bonded to the backing case - they are screwed together. There would be no need to heat them to separate them.
I'd hazard a guess at the weight of the lens being around 50g. Presuming the casting resin has the same density as the glass of the original that would mean a resin cost of £3/casting (presuming no waste). Given the cost of new items this would make for a very big saving.
Out of curiosity, what other car lenses have you cast and why?
