AndrewCS said:Climate ... have never needed the two zone as I`m a loner , had it in the previous Cayman S and found that having the passenger side cooler than driver`s had a negative impact on the system`s performance, why ?
Noooooo! Like many, you’re missing the point Andrew. The two-zone is irrelevant, and anyway I would have thought it at advantage in addressing your complaint. With climate control you just set the temperature and the system does the rest, controlling the temperature and flow (fan speed), whereas with the standard basic system you have to fiddle with the temperature and fan speed to get what you want, which is an unnecessary distraction especially when driving quickly on road and track. That may be OK in a bigger vehicle but in the Cayman’s small cabin with a hot engine bay just behind your back temperatures can change quite quickly.
My biggest gripe - voiced regularly on here - is that on a so-called premium make of vehicle climate control should be standard, and especially on the more expensively optioned cars like the GTS and GT4.
Just my tuppence worth of course, and others are entitled to their own opinions. [
Jeff
