Righto
To keep it all to one page i'll add the new questions here.
The oil pressure sits at 4 when warm which i beleive is right? but flickers around a little when warming up. Does that sound about right?
The fuel gauge and temperature gauge both flicker about a little randomly, i guess there is a problem with the dial but is it an easy fix or a replacement?
Would anyone happen to know if power steering can easily be added? I'm pretty sure it was an option so expect all the associated holes/mounting points will be there? Whats the costs in parts and is it home mechanic job... i realise a steering rack might be required.
Where do i but the clear indicator lenses and is there anywhere that does alternative rear clusters, think i'm happy at the moment with them but would like a look at whats available.
Who does decent (sport?) suspension? I'm interested as it all feels a little tired and i wouldn't mind sharpening it up i guess there are alternative (polyurethene?) bushes too?
Does anyone have a wiring diagram for the radio connectors as someone has decidede a birds nest mixed with connector blocks is a good option. Yuk! I like it all to be nice and smart......
Do the clocks/instuments pull out easy as i need to fit a new bulb. I read about replacing them with leds but i'm happy with standard stuff.
The 3rd setting on the heater works intermittently but only when you turn it past the notch a little which obviously isn't perfect so is not acceptable. Any suggestions as to a fix?
Oh yeah as said this car will be perfect asap as i like the little details. [
The more info and bits you can suggest the better.
Will
