xenon
The interweb has this to say:
Porsche N-rated tyres.
Porsche designs and manufacturers some of the highest performance cars in the world (with the exception of the butt-ugly Cayenne). All this design and performance is worth nothing if you put cheap Korean tyres on your Porsche though, and because of that prospect, Porsche introduced the N rating or N specification system. In order for a manufacturer to be an OE (original equipment) supplier of tyres for Porsches, they must work with the Porsche engineers at the development and testing stage. They concentrate on supreme dry-weather handling but they also spend a considerable amount of time working on wet-weather handling. Porsches are typically very tail-heavy because of the position of the engine relative to the rear wheels, and with traction control off, it's extremely easy to spin one in the wet. Because of this, Porsche specify a set of wet-grip properties which is way above and beyond the requirements of any other car manufacturer.
OE tyres for Porsches must successfully pass lab tests to prove that they would be capable of adequately supporting a Porsche at top speed on a German Autobahn. Once the lab tests are done, they must go on to track and race tests where prototypes are evaluated by Porsche engineers for their high-speed durability, uniformity and serviceability. If they pass all the tests, Porsche give the manufacturer the go-ahead to put the tyres into production and then they can proudly claim they are an N-rated Porsche OEM.
The N-ratings go from 0 (zero) to 4, marked as N-0, N-1 etc. This N-rating, stamped into a tyre sidewall, clearly identifies these tyres as having gone through all the nauseating R&D and testing required by Porsche as described above. The number designates the revision of the design. So for a totally new design, the first approved version of it will be N-0. When the design is improved in some way, it will be re-rated as an N-1. If the design changes completely so as to become a totally new tyre, it will be re-rated at N-0.
If you've got a Porsche, then you ought to be aware that as well as using N-rated tyres, you ought to use matching tyres all around because many Porsches have different sizes tyres front and rear. So for example if you have a Porsche with N-3 rated tyres and the rear ones need replacing but the model has been discontinued, you should not get N-0's and put them on the back leaving the old N-3's on the front. You should replace all of them with the newer-designed re-rated N-0 tyres. But then you own a Porsche so you can certainly afford four new tyres....
One final point. You may go into a tire warehouse and find two tyres with all identical markings, sizes and speed ratings, but one set has an N-rating. Despite everything else being the same, the non-N-rated tyres have not been certified for use on a Porsche. You can buy them, and you can put them on your car, but if you stuff it into the armco at 150mph, Porsche will just look at you and with a very teutonic expression ask why you didn't use N-rated tyres.
Like the site? Help Chris buy a bike. The page you're reading is free, but if you like what you see and feel you've learned something, throw me a $5 bone as a token of your appreciation. Help me buy the object of my desire.
