James_G
Oli As promised here are some photos of the areas you had concerns over from my car. Firstly, I have that trailing piece of rubber on the driver's side, but it's retained under the front wing. However my car has had new wings during it's life, so it was probably tucked under there to keep it out of the way.
Next, the aerial connection isn't visible but the cover is pushed right up and over it. Pulling the cover back shows the connection, so a simple cover re-adjustment for yours I think would be fine.
However the rubber trim has been cut to length on the passenger side, which looks neater. Never noticed this variance before (too busy underneath probably!). Makes me think it's had a new screen at some time.
As for the square blocks, they are both hard up against the bottom of the screen and they don't move around. As previously mentioned, they are probably there to provide some support.
[link=http://i20.photobucket.com/albums/b218/cherry_chariot/Scuttle_4.jpg][/link] If it helps, here's a shot of the base of the windscreen from my BMW, which shows that the rubber trim has been cut to length and I haven't had any problems with wind noise etc, etc.
Hope that helps Cheers James
![Scuttle_1.jpg](http://i20.photobucket.com/albums/b218/cherry_chariot/Scuttle_1.jpg)
![Scuttle_2.jpg](http://i20.photobucket.com/albums/b218/cherry_chariot/Scuttle_2.jpg)
![Scuttle_3.jpg](http://i20.photobucket.com/albums/b218/cherry_chariot/Scuttle_3.jpg)
![Scuttle_4.jpg](http://i20.photobucket.com/albums/b218/cherry_chariot/Scuttle_4.jpg)
![Scuttle_5.jpg](http://i20.photobucket.com/albums/b218/cherry_chariot/Scuttle_5.jpg)
