Hi all I'm a newbie to the forum after picking up a 1985 944 V. cheap with suspected terminal engine damage.
On closer inspection however i can find no terminal engine damage but for some reason the sealing ring on the oil filter had been blown out along a 1/2" section between the filter and its mating face, this caused an loud bang and immediate loss of oil (hence the suspected engine damage). has any one known this to happen before?
the oil filter was non standard (mann) which i have now replaced with an OEM item but have not yet tried the engine (yet to buy some oil!!) although it turns over by hand with no adverse noise or resistance. the filter was not especially tight (i unscrewed it by hand - but only just).
this would hint at a possible blockage in the system (or filter) causing a build up of pressure finally being vented at the oil filter ring, but why no intervention of the pressure relief or by-pass valve(s)
Quite desperate to give the engine a try but i thought i would dig deeper into some more experienced minds before showering the garage in oil.
Dave
Dave
