Yes Melv, a very "Chris" colour
This was the final stage of running the car in and I didn't want to overdo it --- so I was quite happy to bottle out when the rain came.
It's now done 2400 miles and crossed the 2000 mile running in period at the end of the 100 miles I did on track.
Almost exactly 10 miles to the gallon, interesting playing around and finding out what the PDK would do in both automatic and manual --- where strangely it will change down on kickdown if it feels that it has more grunt to offer in a lower gear, but will allow you to hit the rev limiter without changing up !!
I specified also PCCB brakes and was braking early and keeping it all very smooth --- so was pulling away from Kevin out of the corners and down the straights, but he was catching me up on braking. At the end I did think I could detect some wear on the discs / pads --- but when jet-washed it was just brake dust on the discs (none in the holes) --- and there is now absolutely no evidence that the car has been used in anger ! So next time I can try harder ! !
Balance, lovely, gearbox --- you have to keep an eye on the gear display rather than have a sixth sense for where you left the gear stick, and to be honest it all takes a little getting used to.
But on a lazy day in automatic, it is absolutely fantastic !! Truly amazingly good --- and not bad on the track !
Definitely a learning process, which was precisely what I wanted.
One thing that is interesting, the DI 3.4 engine has a compression ratio of 12.5 :1 ... so there is an amazing amount of engine braking.
Another thing that is interesting, is that it would appear to be the same engine as that fitted to the new 991 C2 ...
So maybe it's giving a little more power than the paperwork would suggest ?
What do you my passengers reckon ??
P.S. Sorry to have been so busy .. have missed the banter .. [
Passenger rides willingly given ... and there should be N rated supersports later this year ?
