Nice conversion
- Thread starter charles.y
would guess that includes dumping the fat US spec bumpers as well, TonyORIGINAL: charles.y .... and saves 120 lbs [8|]
Sort of. I quite fancy a set but, because the light units sit back from where the originals are, my air filter wouldn't fit. I agree that they don't look as good as the original (with the lights off) but I like the sound of the weight saving and - perhaps better still - it is something less to go wrong. The other thing against them is rectangular lights don't seem to work as well as round lights. They are also lower so don't give as good light coverage. While they will cause additional drag (not much of a concern bellow 100mph), if you are into serious night driving, a good set of originals (with IceShark wiring) are probably much better.ORIGINAL: Fen ...... but it does free up space under the bonnet ......
I haven't seen the underbonnet look of a car with such a conversion so I had assumed it would help. I had to take a cutting disk to the brace on the back of my passenger side light to fit my air filter in and I guess there might not be much to be gained over that configuration of pop-up, but there is space to be gained elsewhere by removing the motor and the bar across the front that lifts the pods (which I imagine is substantial and correspondingly heavy, give its purpose).ORIGINAL: John SimsSort of. I quite fancy a set but, because the light units sit back from where the originals are, my air filter wouldn't fit. I agree that they don't look as good as the original (with the lights off) but I like the sound of the weight saving and - perhaps better still - it is something less to go wrong. The other thing against them is rectangular lights don't seem to work as well as round lights. They are also lower so don't give as good light coverage. While they will cause additional drag (not much of a concern bellow 100mph), if you are into serious night driving, a good set of originals (with IceShark wiring) are probably much better.ORIGINAL: Fen ...... but it does free up space under the bonnet ......
sawood12
George Elliott
sawood12
