chriscoates81
Hi guys, whats your opinions on nitrogen fills in tyres?
I agree.ORIGINAL: thirteeneast Hello, Waste of Money.
Actually there is. Now retired, but I have a vehicle refinement background and we often used a nitrogen fill to change the tyre acoustic cavity mode to see what effect it was having on interior noise. Sometimes the cavity mode can couple strongly with the suspension components to generate structure-borne noise, or it may just find an airborne noise route into the cabin. So, Lancerlot, your car might actually be quieter than the those of the non-believers..! JeffORIGINAL: Lancerlot Nothing more to be said then! [8|]
That'll keep his Mrs happier then []ORIGINAL: Motorhead So, Lancerlot, your car might actually be quieter than the those of the non-believers..!
Actually, "Not non believers" Just think its better suited to a Nascar sponsored team than going out to the supermarket.ORIGINAL: MotorheadActually there is. Now retired, but I have a vehicle refinement background and we often used a nitrogen fill to change the tyre acoustic cavity mode to see what effect it was having on interior noise. Sometimes the cavity mode can couple strongly with the suspension components to generate structure-borne noise, or it may just find an airborne noise route into the cabin. So, Lancerlot, your car might actually be quieter than the those of the non-believers..! JeffORIGINAL: Lancerlot Nothing more to be said then! [8|]
Had mine done for free at Kwik-Fit but they only charge £1 per wheel. I read up on this and I thought the tyre wear was extended as Nitro prevents rubber corrosion, plus the pressures remained constant for longer period. JohnORIGINAL: Spy Most of the places I have used, Nitrogen fill is no extra cost. I am not sure I would have it if I had to pay £10-£20 more [:'(]
Just a throw away comment Richard. I have no experience on the benefits, or otherwise, of nitrogen fill for normal driving. JeffORIGINAL: thirteeneastActually, "Not non believers" Just think its better suited to a Nascar sponsored team than going out to the supermarket.ORIGINAL: MotorheadActually there is. Now retired, but I have a vehicle refinement background and we often used a nitrogen fill to change the tyre acoustic cavity mode to see what effect it was having on interior noise. Sometimes the cavity mode can couple strongly with the suspension components to generate structure-borne noise, or it may just find an airborne noise route into the cabin. So, Lancerlot, your car might actually be quieter than those of the non-believers..! JeffORIGINAL: Lancerlot Nothing more to be said then! [8|]
Jeff, Neither have many of the posters here, I would suspect! [] The OP asked for opinions on N2 fill and he's had them in spades. My offering, for what it's worth, is that it IS advantageous - but that's only based on 30 years of Porsche ownership and neither do I use my car just for transport or supermarket shopping expeditions. [] Also, it occurs to me the more power available, the greater is the benefit. If I waltzed into my OPC for N2, a Porsche trained technician would fill and purge each corner at least 3 times, using calibrated equipment and it would likely take ½ hour or so to complete. I do not therefore think a £10-£20 charge would be at all unreasonable. If I were buying tyres there, then I've no doubt nitrogen would be included at no extra cost. [] Nothing like a good, healthy debate. [&:] Regards, CliveORIGINAL: Motorhead I have no experience on the benefits, or otherwise, of nitrogen fill for normal driving. Jeff
