ORIGINAL: jukn
After much deliberation i have decided to go with warranty works when its due for renewal on 1st november. This is costing me £823 for three years (the third year is free if you pay up front for two) and covers most major components engine and electrics.
I don't do lots of miles in the car but would like some peace of mind. if you're in the same boat it may be worth a look?
Julie - as a follow on to my reply above - check the small print first. Their policy booklet wasn't downloadable, (suspicious?), but from other parts of their web site I gleaned the following ...
A) 36 months Platinum (£2500 claim limit) ... so, although engine and gearbox are covered, you won't get a 996 engine or gearbox for that price, fitted, incl VAT.
B) Q: Do I have to have the warranty book stamped? A: No, but we recommend that you get the book stamped each time it's serviced. This is because if you have a claim the service history may need to be checked and if it's recorded in the book then it can save us having to phone you to check its service history. Always keep the receipts too.
Means: If you miss a service by a day or mile, your claim will be rejected.
C)
Q Can I claim for a broken part that was there before I bought the policy?
A No. The car must be in sound condition before you take the warranty out.
Means: They could well (& probably will) tell you that your cracked cylinder liner was due to ovalling and weakening of the liner over a long period of time (e.g. before the warranty was taken out) and hence not covered.
D) Q: Do I have to use a garage recommended by you to have the vehicle repaired? A: Repairs should be made by your supplying garage or a garage of your choice who is willing to work for our repair rate of £58.75 (inc VAT)
- You doubt you'll get an OPC to work for £50+VAT, so you'll be searching around for a cut price indi, I guess.
E) You will be required to authorise the garage to investigate the fault to determine what has failed and the relevant costs involved.
- Watch out here. Investigation costs could be substantial - for which you have to pay for - From my experience, this means they are not re-imbursed by the warranty company, even if the fault is found.
Personally, I wouldn't touch with it with the proverbial bargepole.
