Non running 3.0 SC
According to the wiring diagram for the '81 SC the ignition switch feeds the CDI (Red wire) and the fuel pump relay (Red wire from Fuse 16) separately, so I don't think you should lose sparks with the relay out. However, if you are picking up power for the CDI from the Red/White wiring that is connected to the Warm-up regulator, the Supplementary Air Valve or the Temperature Valve, then there will be no power with the fuel pump relay taken out.
Hope this helps.
Philip
