scam75
Well-known member
blade7 said:Did you have to uprate the wiring ?
No. Pretty much plug n play.
Stuart
scam75 said:blade7 said:Did you have to uprate the wiring ?
Stuart
blade7 said:scam75 said:blade7 said:Did you have to uprate the wiring ?
Stuart
Thanks. Just a thought, have you checked the cables aren't getting hot after it's been running a while ?
blade7 said:Uprating the wiring is recommended for Bosch 044 pumps, may be an idea to check your wiring.
scam75 said:blade7 said:Uprating the wiring is recommended for Bosch 044 pumps, may be an idea to check your wiring.
I wasn't aware of that. Will do.
Stuart
robwright said:I run the 9XX fuel pump from JMG with 55lb injectors. You can get away with standard with these injectors but it is a good upgrade and good future proofing. There was never any mention of upgrading wiring. It runs on the same size fuse so don't see why a wiring upgrade would be necessary?
There was some modification to wiring and vacuum hoses to fit the Augment gear but I didn't do it. Was all left to Tom at Augment.blade7 said:Did you have to uprate the wiring ?
Zeusy said:O.k. My trusty old 944 S2 was running absolutely fine and dandy it had just been MOT tested and the garage rang to say I could collect it. I duly settled the bill got in the drivers seat switched off the immobiliser turned the key the dash lights all lit up as normal I turned the key further in order to engage the starter motor and ...........nothing[]. This had never happened before in fact with the new battery and new starter motor I had fitted several months prior to this my car was an excellent starter. It had only just been started moved and parked up without any signs of trouble a few minutes before my arrival. Two months later the car is still at the garage with the same fault. There seems to be no apparent reason why this should be. If anyone has any bright ideas or suggestions as to how we can get it running again I would be very pleased to hear from them.
