pauljmcnulty
Are there any questions that i can throw at a seller that will have them reacting in a way which will tell me that they are upfront or not?
Warrants a reply of it's own. [&:]
I guess a very abbreviated guide would be:
When were the belts changed, year and mileage as mentioned. By whom, and what else did they change, i.e. water pump. If it's a 16V car when was the timing chain changed or checked, where is the evidence.
When did it have a clutch? This is a £1K job, and although they last forever early clutches have a rubber centre that breaks up when old.
I want to take the plastic vents out of the b-pillar and look inside the sills. That small blister on the outside might look small but the stonechip film hides a multitude of sins. Not like an old Scimitar and it's rotten chassis legs, but still rust. Put a torch or a camera through here, it pops out via the little tab on top of the vent:
Expect loads of waxoyl at best, or daylight at worst. In between is usual, you have to weigh up the cost of repairing a bad one or treating light rust and forgetting it.
If it's a red car, is it unusually highly polished? Red fades to pink, it could be a lovely example that's always ben garaged or a good example of a machine polisher. Fen used to say that guard's red was the most expensive option on a 944, as it will need a respray at some point. [8|]
Later cars suffer from caliper corrosion, ask me about that one. [:'(] All cars have fuel and brake lines that are either new, or need doing soon. All these things are consumables, and I'd not expect a perfect car, but they should be inspected by the service centre in the same way as things like tyres. Evidence of repairs, or a report that says they are fine, go to prove that the car has been looked after.
Ultimately, they aren't any different from other cars: buy from someone you trust, buy on recent history and current condition, look for cars with piles of paperwork, forum users often detail the history of their car for years, get an inspection from a 944 specialist if unsure.
Then, throw a few grand at the best car you'll ever own. If it's a lemon, cut your losses and buy another one. [
